- Timestamp:
08/11/21 12:26:03 (3 years ago)
- Author:
pranav
- Comment:
Legend:
- Unmodified
- Added
- Removed
- Modified
v56
v57
174 | 174 | * Wrote a patch to add support for the second bank, sent to mentors to review. |
175 | 175 | * Found a circumventing option of using device tree overlays to circumvent and not change/patch pre-existing GPIO code. |
176 | | * Mentors are to decide if we are to go forward witth the patch or use device tree overlays. |
177 | | |
| 176 | * Mentors are to decide if we are to go forward with the patch or use device tree overlays. |
| 177 | * July 14: Sixth Meet |
| 178 | * Discarded the first GPIO patch because of too many changes to pre-existing code. |
| 179 | * Wrote and Tested a more compact GPIO patch, sent to mentors for review. |
| 180 | * Started working on testing the i2c, looked at previous i2c driver examples on rtems. |
| 181 | * July 21: Seventh Meet |
| 182 | * Wrote a driver to read temperature from a sensor using the i2c on the RPi BSP |
| 183 | * Wrote a test for the driver using both the BSPs. Both worked. |
| 184 | * Started work on SPI driver. |
| 185 | * July 28: Eighth Meet |
| 186 | * Wrote a driver to read temperature from a sensor using the SPI on the Rpi BSP |
| 187 | * Wrote a test for the driver using both the BSPs. Both work. |
| 188 | * August 4: Ninth Meet |
| 189 | * Tried finding documentation on the Rpi Boot process and working of the Rpi mailbox registers. |
| 190 | * The mailbox now needs a send event poke, which was missing in the Rpi implementation |
| 191 | * Added changes to the SMP on the the RPi BSP. Sent patch for the same. |
178 | 192 | |
179 | 193 | == Ida == |
