322 | | |
323 | | |
324 | | |
325 | | |
326 | | |
| 322 | * '''June 24''' Fourth meeting |
| 323 | * Progress: |
| 324 | * Tried to build ptpd by hand, the configure ran properly, however, build again failed with different errors |
| 325 | * Halted the work on RSB because it is important to build the packages by hand first. |
| 326 | * Revisited the epics-base code to study and make note of things where the change is required. |
| 327 | * Blockers: |
| 328 | * No Blockers as such |
| 329 | * Next up: |
| 330 | * Start the work back on EPICS community codebase first. Working on files mentioned below will be a priority to get things worked. |
| 331 | epics7/modules/libcom/RTEMS/posix/rtems_init.c |
| 332 | epics7/modules/libcom/RTEMS/posix/rtems_netconfig.c |
| 333 | |
| 334 | |
| 335 | |
| 336 | |
| 337 | |
| 338 | |
| 339 | |
| 340 | |
