Changes between Version 1 and Version 2 of GSoC/2019/PRU_support
Ignore:
Timestamp:
May 9, 2019, 6:35:19 AM (17 months ago)
Author:
Nils Hölscher
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • GSoC/2019/PRU_support
    v1 v2
    2222Since the PRU is designed to be more predictable than your normal CPU, it is able to access I/O peripherals in a deterministic manner.
    2323This behavior will be used to demonstrate that code is running on the PRU and not the CPU.
    24 The PRU is able to output a square wave with constant wavelength on the BBB s Pins.
    25 The SOC s CPU is not capable of this.
     24The PRU is able to output a square wave with constant small wavelength on the BBB s Pins.
     25The SOC s CPU is not capable of this, due to pre-emptive behaviour of most OS s.
    2626
    2727== References ==
