Changes between Version 98 and Version 99 of GSoC/2018
Ignore:
Timestamp:
Jun 27, 2018, 2:12:55 PM (16 months ago)
Author:
Vidushi Vashishth
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • GSoC/2018
    v98 v99
    348348    * Setup qemu for ARM as working environment to try qemu fat files and file transfer as a method of transport.
    349349    * Write a blog on the possible transport mechanisms to be explored
    350
     350* June 27:
     351 * Progress so far:
     352    * I am able to generate CTF traces using the babeltrace method. I saved the rtems trace output in a raw file and used babeltrace conversion graph to convert the traces into CTF format. I have documented the process in a blogpost : https://vidushivashishth.github.io/eighthpost/
     353    * I have written a yaml configuration file to try the barectf method of trace conversion. I will be trying this out along with my phase 2 objectives.
     354    * I have setup qemu for ARM machines as the working environment for testing transportation mechanisms.
     355 * Blockers:
     356    * Babeltrace calls inside the rtems shell shows no output. One way around could be to transport the traces off the target to the host and then run the conversion to CTF using babeltrace.
     357* Next:
     358    * Try qemu fat files and file transfer protocol as a transportation mechanism from the target to the host.
    351359
    352360== Salil Sirotia ==
