Changes between Version 13 and Version 14 of GSoC/2017/RTEMSTesterImprovements
Ignore:
Timestamp:
May 24, 2017, 2:00:49 PM (2 years ago)
Author:
Tanu Hari Dixit
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • GSoC/2017/RTEMSTesterImprovements
    v13 v14
    225225    continue'
    226226}}}
     227
     228There should be no user-interaction (like keyboard input). This testing should be scripted. So the settings file can be a passed as an INI file or a paramater --with-parameter. ----insert the pros for this---
     229We have thought of naming the section [bsp] as [erc32] or the respective bsp name in a top level configuration file that includes all others so that any change in tool (or a macro file) can be checked. Important quote from Chris: "If we have 20 bsp scripts and you make a change to the way they are parsed and loaded you would need to run the tool 20 times to check all scripts. The parsing (and the tool in general) will have to be checked once this way."
