Changes between Version 11 and Version 12 of GSoC/2017/RTEMSTesterImprovements
- Timestamp:
- 05/24/17 13:29:58 (7 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v11 v12 21 21 * Ser2net is used for providing remote access to a unit’s server ports over telnet. It is proposed to add support for a telnet console in rtems-tester so that it becomes convenient to telnet into serially connected devices and test applications on them, remotely. 22 22 * I’ll add simulator recipes for RTEMS to work with gem5 for sparc64/usiii and arm/realview_pbx_a9_qemu BSPs. 23 * I also plan to export the results of rtems-tester to xml format so that it can be plotted easily and used for other analysis as developers and users deem fit.23 * I also plan to export the results of rtems-tester to xml format and text-report so that it can be plotted easily and used for other analysis as developers and users deem fit. 24 24 25 25 26 == Updates: == 27 We have decided to rewrite configuration files in INI format instead of YAML in the absence of standard support for YAML in Python. Using PyYAML would add a dependency in the tool that would be difficult to handle across all hosts we support. 28 === Handling macro values like %{_rtscripts}: === 29 We will use RawConfigParser to parse the macros from INI files. It handles %(value) and %{value} both as format specification. 30 === Handling those macro files that need user-specific things === 31 We plan on taking assistance from a user-specified "settings" file that can help the main configuration file with user-specifics. THe ini file should have some defaults that lead to suitable errors which the user can rectify in the settings file. 32 === Macro Maps === 33 The macro maps are like namespaces and shouldn't be mixed for re-usability in different macro files for different BSPs. 34
