Changes between Version 53 and Version 54 of GSoC/2016
Ignore:
Timestamp:
May 27, 2016, 7:23:25 PM (4 years ago)
Author:
Vivek Kukreja
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • GSoC/2016
    v53 v54
    5151|| Habeeb Olufowobi || dipupo || [https://devel.rtems.org/wiki/GSoC/2016/rtems_port_TM4C/ Wiki] || [https://github.com/Dipupo/RTEMS_on_TI_LaunchPad Github] || [http://rtemstolaunchpad.blogspot.com/ Blog] || TBA
    5252|| Wonjun Hwang || Wonjun || [https://devel.rtems.org/wiki/GSoC/2016/RTEMS%20improvement%20for%20Jailhouse%20hypervisor/ Wiki] || [https://github.com/hwj1593/GSoC2016_RTEMS-Jailhouse Github] || [http://wonjunhwang.blogspot.kr/ Blog] || TBA
    53 || Vivek Kukreja || vivekk || [https://devel.rtems.org/wiki/GSoC/2016/RTEMStraceimprovements/ Wiki] || [https://github.com/vivek9191/rtems Github] || TBA || TBA
     53|| Vivek Kukreja || vivekk || [https://devel.rtems.org/wiki/GSoC/2016/RTEMStraceimprovements/ Wiki] || [https://github.com/vivek9191/rtems Github] || [http://rtems-tracing-tweaks.blogspot.in Blog] || TBA
    5454|| Sai Charan Sane || sacha || [https://devel.rtems.org/wiki/GSoC/2016/LwIPwithRTEMS/ Wiki] || [https://github.com/sacha23/LwIP-GSOC-16 Github] || [http://lwipwithrtems.blogspot.com Blog] || TBA
    5555The columns are to be filled in as follows:
    9292== Sambeet Panigrahi ==
    9393* May 25: As per my proposal the first deliverable  is an easy to use Autoproj version of Rock building on RTEMS with appropriate tutorials to guide the user.I am now updating all the old scripts with newer versions of softwares.Till now I have replaced the traditional makefiles of RTEMS with building enabled by RSB. My next task is to update the Rock dependencies.I am going to cross compile OmniORB package now which is to be ported on RTEMS.
     94
     95== Vivek Kukreja ==
     96* May 25: In my first deliverable I will modify the code for capturing user extensions and trace-buffering to obtain respective traces in CTF format. For trace-buffering I've made changes to the trace linker to produce CTF metadata and buffering functions to produce CTF bitstream. I'm currently working on capture engine code to translate user extension traces to CTF.
