Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
Changes between Version 93 and Version 94 of GSoC/2015
Ignore:
Timestamp:
05/19/15 16:15:32 (9 years ago)
Author:
Jarielle Catbagan
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • GSoC/2015
    v93 v94
    9797
    9898* May 19: First task is adding networking support. For this I will be porting ethernet driver from FreeBSD to rtems-libbsd. I have been studying some already ported drivers from FreeBSD to rtems-libbsd. Current progress,I pulled the driver from Freebsd and compiled it with the latest rtems-libbsd. Next target is to code all the rtems specific changes needed and check with the mentors whether that is sufficient.Then try to solve any issues that arises.
     99
     100== Jarielle Catbagan ==
     101
     102* May 19: Currently, I have a basic image to perform UART booting on the BBB.  As of right now I am transferring my changes from the initial Umon 1.19 sources to the new revised Umon git source tree obtained from the  RTEMS repos.  Furthermore, I am also working on a copy of the CSB740 port by replacing the CSB740 specifics with that of the BBB/ARM Cortex-A8 while maximizing code reuse as much as possible.  From now up uptil the next status update, I will continue finishing the remaining logistics of the project, continue working on the base files of Umon to get an initial image up and running while committing and pushing my changes regularly.  I will draw up inspiration from existing Umon port implementations for the design of the BBB port.  Finally, I will continue looking into the ARMv7A ARM Architecture Reference Manual, specifically the application level and system level architecture to help me understand the fundamentals of RTEMS and Umon.
