Changes between Version 4 and Version 5 of GSoC/2015/NestedMutex
- Timestamp:
- Jun 5, 2015, 11:42:49 PM (6 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v4 v5 9 9 '''Introduction:''' The strict order mutexes in RTEMS is based on LIFO ordering. So whenever thread tries to acquire mutex lock, its priority before acquiring the lock is pushed to that mutex’s thread queue. So whenever thread release any lock then that lock’s queue is consulted and thread’s priority is restored. So this mechanism of restoring priority may induce unbounded priority inversion if higher priority thread is contending for a lock still hold by our candidate thread. This project deals with solving this problem and developing validation methods using JPF. 10 10 11 = Configuration Setup Steps = 12 * Build RSB by following this [https://docs.rtems.org/rsb link] from 1.0 to 2.4 Building step(inclusive). 13 * Now clone the RTEMS repository from [https://github.com/saurabhgadia4/rtems Personal Github Link] 14 15 {{{ 16 sudo apt-get install pax (you require it for compiling libtests from testsuite) This step should be performed before bootstraping. 17 18 cd rtems 19 20 export PATH=/opt/rtems/4.11/bin:$PATH 21 22 export PATH=~/devlopment/rtems/4.11/bin:$PATH 23 24 ./bootstrap 25 26 cd .. 27 28 mkdir b-sis 29 30 cd b-sis 31 32 ../rtems/configure --target=sparc-rtems4.11 --enable-rtemsbsp=sis --enable-tests --disable-posix ENABLE_STRICT_ORDER_MUTEX=1 33 34 make 35 36 sudo PATH=/opt/rtems/4.11/bin:${PATH} make install 37 }}} 38 39 * Above steps if performed correctly will compile your RTEMS code and you can go ahead with your test suites. 11 40 = Progress = 12 41 * Proposed solution for the existing problem. You can find presentation which also contains test cases in attachment section.
