Changes between Version 16 and Version 17 of GSoC/2012
Ignore:
Timestamp:
Mar 5, 2013, 7:18:11 PM (7 years ago)
Author:
Jennifer
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • GSoC/2012
    v16 v17
    9191The IRC Handle column is your handle on IRC. RTEMS folks hang out in the #rtems channel on irc.freenode.net.
    9292
    93 The Proposal Title should be self-explanatory. If approved, we will ask you to create a Google Code project to host your work and link to it here. You will need to give at least your mentor and Joel Sherrill read/write access.
     93The Proposal Title should be self-explanatory. If approved, we will ask you to create a [http://code.google.com/  Google Code] project to host your work and link to it here. You will need to give at least your mentor and Joel Sherrill read/write access.
    9494
    95 The Google Docs URL is your proposal on Google Docs that can be reviewed and commented on by mentors.
     95The Google Docs URL is your proposal on [http://docs.google.com/  Google Docs] that can be reviewed and commented on by mentors.
