Changes between Version 1 and Version 2 of GSoC/2012/Testing
- Timestamp:
- 08/23/12 02:11:22 (12 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
GSoC/2012/Testing
v1 v2 1 1 = RTEMSTestingGSOC2012 = 2 2 3 = Testing Framework Comparison and Sanity Check = 3 = Testing Framework Comparison and Sanity Check = 4 5 I compared 10 testing framework by unit testing functionality and mocking capability.For each framework, I modified several tests from current test suite, compile them with RTEMS compilers, simulate the new tests with Sparc architecture, and compare the results to ensure that framework used could work correctly for RTEMS based testing. 6 The detailed test framework review can be accessed with this link: [TestingReview:Testing Framework Comparison and Sanity Check] 4 7 = Structure Design for New Test Suite = 5 8 = Conversion Plan of Current Test Suite to New Test Suite =
