Changes between Version 1 and Version 2 of GSoC/2011/ISO9660_Filesystem
- Timestamp:
- 06/30/11 18:23:15 (13 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v1 v2 1 1 = ISO9660 Filesystem = 2 3 2 4 3 … … 9 8 '''Possible Mentors:''' Multiple possible. Ask if interested. 10 9 11 '''Status:''' No work performed10 '''Status:''' ''Work in progress (C. Huriaux, GSoC 2011)'' 12 11 13 12 '''Introduction:''' This project will implement the ISO9660 file system on RTEMS. This is the filesystem used on CD-ROMs and DVD-ROMs. It may be possible to port an implementation from another OS or project (with appropriate license). … … 21 20 '''Acknowledgements''' 22 21 * None yet. 23 = Miscellaneous Sections=22 = Actual work = 24 23 25 As the project progresses, you will need to add build instructions, etc and this page will evolve from a project description into a HOWTO.24 The actual code could be retrieved through the dedicated [http://code.google.com/p/rtems-iso9660/ Google Code project]. The [http://code.google.com/p/rtems-iso9660/source/checkout SVN repository] could be used to check out the code. 26 25 = References = 27 26 … … 29 28 * http://en.wikipedia.org/wiki/ISO_9660 30 29 31 * TBD30 * http://www.ecma-international.org/publications/standards/Ecma-119.htm 32 31 33 32 '''Other sections:''' If you have more to say about the project that doesn't fit in the proposed sections of this template, feel free to add other sections at will. 34 35 36 http://en.wikipedia.org/wiki/ISO_9660
