Changes between Version 2 and Version 3 of GSoC/2009/Wrapup
- Timestamp:
- 10/12/09 22:23:45 (14 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
GSoC/2009/Wrapup
v2 v3 12 12 Xi also implemented an LCD framebuffer driver for use with RTEMS. This was a tie-in to the work of Roxana Leontie (code at http://code.google.com/p/rtems-nano-x/). Roxana was not a GSoC student but operated under GSoC rules and was funded using the Google donation to the project in conjunction with a donation from OAR Corporation. Her project was updating the Nano-X (http://www.microwindows.org/) RTEMS port and providing a new RTEMS framebuffer device interface. She targeted a standard PC and tested using QEMU (http://www.nongnu.org/qemu/). Roxana's first succesful demonstration was running the Nano-X Minesweeper program on RTEMS. Apparently neither she nor I is particularly good at Minesweeper. 13 13 14 14 [[Image(Microwindows_Minesweeper.jpg)]] 15 15 16 16 As she progressed, Xi updated his LCD framebuffer driver to match her new interface. Although not a requirement for either student, I expect we will be running Nano-X soon on Skyeye's ARM PXA255 simulation using Xi's framebuffer driver. The following screenshot is a test screen from Roxana using Xi's framebuffer.
