- Timestamp:
08/08/08 20:50:41 (16 years ago)
- Author:
YanMiao
- Comment:
/* Progress */
Legend:
- Unmodified
- Added
- Removed
- Modified
v27
v28
58 | 58 | |
59 | 59 | 2008.7.14: fixup code |
| 60 | |
| 61 | 2008.7.17: eliminate the _reent structure defined in RTMES, using the one defined in newlib instead |
| 62 | |
| 63 | 2008.7.19: testing newlib patch on real hardware(sparc) |
| 64 | |
| 65 | 2008.7.23: testing devfs code on real hardware(sparc) |
| 66 | |
| 67 | 2008.7.25: add a data member to the main device table structure; add devFS_stat function ; fixup code of devFS_Show function |
| 68 | |
| 69 | 2008.7.30: tesing new code on real hardware(sparc) |
| 70 | |
| 71 | 2008.8.5: with Ray's lasted patch for arm, rtems cvs can successfully run on skyeye; test minimum.exe with skyeye configuration of 32KB ram |
| 72 | |
| 73 | 2008.8.6: updated the comments in the header files |
| 74 | |
| 75 | 2008.8.8: sending Ray the latest document for review |
60 | 76 | = Deliverables = |
61 | 77 | |
