| 16 | }}} |
| 17 | |
| 18 | |
| 19 | {{{#!comment |
| 20 | |
| 21 | == <Task Name> == |
| 22 | |
| 23 | === Task Description === |
| 24 | |
| 25 | === Directions for Students === |
| 26 | |
| 27 | |
| 28 | === Directions for Mentors === |
| 29 | |
| 30 | }}} |
| 31 | |
| 32 | = Google Code-In Projects = |
| 33 | |
| 34 | If RTEMS is to participate in [http://code.google.com/opensource/gci Google Code-In], then we have to have a nice list of small tasks divided into the following categories. This is the list that participants can see for general information and dynamic task-specific instructions, and the specific tasks are in a spreadsheet and tracked in a git repository. |
| 35 | |
| 36 | == Coding == |
| 37 | |
| 38 | * [wiki:GCI/Coding/HelloWorld Run and Modify GSOC Hello World Procedure.] This task can be performed once per student. It gives you "task credit" for installing the RTEMS development environment which is needed to perform some of the other tasks. |
| 39 | * [wiki:GCI/Coding/POSIXTimingTest Add a POSIX Timing Test.] |
| 40 | * [wiki:GCI/Coding/RefactorBSPs Refactoring Board Support Packages.] |
| 41 | * [wiki:GCI/Coding/AddPerSectionSupportToBSPs Turn on Per Function and Data Item for a BSP] |
| 42 | |
| 43 | |
| 44 | == Documentation / Training == |
| 45 | |
| 46 | * [wiki:GCI/Documentation/Doxygen Doxygen Related Tasks.] |
| 47 | * [wiki:GCI/Documentation/FileHeaders Fix Comment Block at Top of Header Files.] |
| 48 | * [wiki:GCI/Documentation/ClassicAPIRequirements Classic API Requirements Document.] |
| 49 | |
| 50 | |
| 51 | == Outreach / Research == |
| 52 | |
| 53 | * [wiki:GCI/Outreach/Citations Update References]. |
| 54 | * [wiki:GCI/Outreach/Tutorials Tutorial Tasks]. |
| 55 | * [wiki:GCI/Outreach/HelloWorldVideo Create a video of GSOC Hello World Procedure.] |
| 56 | * [wiki:GCI/Outreach/Middleware Middleware Framework Evaluation.] |
| 57 | |
| 58 | == Quality Assurance == |
| 59 | |
| 60 | * [wiki:GCI/QA/ImproveEnglish Improve English Language Use.] |
| 61 | * [wiki:GCI/QA/InvestigateTicket Investigate A Ticket.] |
| 62 | |
| 63 | == User Interface == |
| 64 | |
| 65 | * [wiki:GCI/UI/WikiTBR Fix Wiki TBR Pages.] |
| 66 | * [wiki:GCI/UI/CoverImage Create a Cover Image.] |
| 67 | |
| 68 | == Testsuite == |
| 69 | |
| 70 | * [wiki:GCI/Testsuite/UnitNames Unit test names] |
