Changes between Version 17 and Version 18 of GCI/SampleTasks
- Timestamp:
- 09/14/18 21:11:09 (6 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
GCI/SampleTasks
v17 v18 34 34 || Create POSIX Timing Test psxtmmqrcvblock01 (13-#3) || This task consists of creating the timing test testsuites/psxtmtests/psxtmmqrcvblock01 for the POSIX API method when used in a particular manner. The test case is: mq_receive: not available: block. Please check testsuites/psxtmtests/psxtmtests_plan.csv and make sure this description match that in the spreadsheet file. Also there may be multiple test cases in one test name. The .csv file along with advice from mentors is truth. In some cases a single test name may have multiple timing cases and be listed on two lines in the .csv file. Just be careful. As a hint if there is no dash in the description then this is the only case of interest for that method. If there are multiple methods then test both methods. The test should be created using the test instantiation helper and templates in rtems-testing/rtems-test-templates. This test will be using the template: psxtmtest_blocking. See https://devel.rtems.org/wiki/GCI/Coding/POSIXTimingTest for more details. The outcome of this task will be a patch to add the new test to RTEMS. || 1 || hiddenpearls || C,benchmarking,testing || 0 || 1,4 || 3 || psxtmtest 35 35 || Create POSIX Timing Test (13-#5) || This task consists of creating the timing test testsuites/psxtmtests/ for the POSIX API method when used in a particular manner. The test case is: . Please check testsuites/psxtmtests/psxtmtests_plan.csv and make sure this description match that in the spreadsheet file. Also there may be multiple test cases in one test name. The .csv file along with advice from mentors is truth. In some cases a single test name may have multiple timing cases and be listed on two lines in the .csv file. Just be careful. As a hint if there is no dash in the description then this is the only case of interest for that method. If there are multiple methods then test both methods. The test should be created using the test instantiation helper and templates in rtems-testing/rtems-test-templates. This test will be using the template: . See https://devel.rtems.org/wiki/GCI/Coding/POSIXTimingTest for more details. The outcome of this task will be a patch to add the new test to RTEMS. || 1 || chrisjohns || C,benchmarking,testing || 0 || 1,4 || 3 || psxtmtest 36 || Design a square organization logo || We could use a nice square variant of our current logo at at least 300 px per inch. || Infinite || "joelsherrill@gmail.com,gedarebloom@gmail.com" || graphics,logo || false || 2 || 3 || TBR 37 || Design a new organization logo || We could use a new logo. Be creative. || Infinite || "joelsherrill@gmail.com,gedarebloom@gmail.com" || graphics,logo || false || 2 || 3 || TBR 38 || Design a T-Shirt || RTEMS needs some cool t-shirt designs. || Infinite || "joelsherrill@gmail.com,gedarebloom@gmail.com" || graphics,logo,t-shirt || false || 2 || 3 || TBR 39 40 41
