| 27 | || Investigate/Fix Bug: Ticket #1405 || First complete one of the Getting Started tasks.<p><p>Investigate the bug described in Ticket #1405 on [the RTEMS Trac](https://devel.rtems.org/ticket/1405) Follow the [directions for this task](https://devel.rtems.org/wiki/GCI/QA/InvestigateTicket) on our wiki. The outcome of this task will be a comment on the ticket to suggest a path forward. If a bug fix is available || you may be expected to test the fix and possibly produce an updated patch. || 1 || "joelsherrill@gmail.com,gedarebloom@gmail.com,vattamsantosh@gmail.com" || "c,debugging" || false || "1,3,4" || 5 || bugfix |
| 28 | || Investigate/Fix Bug: Ticket #1406 || First complete one of the Getting Started tasks.<p><p>Investigate the bug described in Ticket #1406 on [the RTEMS Trac](https://devel.rtems.org/ticket/1406) Follow the [directions for this task](https://devel.rtems.org/wiki/GCI/QA/InvestigateTicket) on our wiki. The outcome of this task will be a comment on the ticket to suggest a path forward. If a bug fix is available || you may be expected to test the fix and possibly produce an updated patch. || 1 || "joelsherrill@gmail.com,gedarebloom@gmail.com,krzysztofmiesowicz@gmail.com" || "c,debugging" || false || "1,3,4" || 5 || bugfix |
| 29 | || Investigate/Fix Bug: Ticket #2024 || First complete one of the Getting Started tasks.<p><p>Investigate the bug described in Ticket #2024 on [the RTEMS Trac](https://devel.rtems.org/ticket/2024) Follow the [directions for this task](https://devel.rtems.org/wiki/GCI/QA/InvestigateTicket) on our wiki. The outcome of this task will be a comment on the ticket to suggest a path forward. If a bug fix is available || you may be expected to test the fix and possibly produce an updated patch. || 1 || "joelsherrill@gmail.com,gedarebloom@gmail.com,heshamelmatary@gmail.com" || "c,debugging" || false || "1,3,4" || 5 || bugfix |
| 30 | || Investigate/Fix Bug: Ticket #2581 || First complete one of the Getting Started tasks.<p><p>Investigate the bug described in Ticket #2581 on [the RTEMS Trac](https://devel.rtems.org/ticket/2581) Follow the [directions for this task](https://devel.rtems.org/wiki/GCI/QA/InvestigateTicket) on our wiki. The outcome of this task will be a comment on the ticket to suggest a path forward. If a bug fix is available || you may be expected to test the fix and possibly produce an updated patch. || 1 || "joelsherrill@gmail.com,gedarebloom@gmail.com,chriscjohns@gmail.com" || "c,debugging" || false || "1,3,4" || 5 || bugfix |
| 31 | || Investigate/Fix Bug: Ticket #1778 || First complete one of the Getting Started tasks.<p><p>Investigate the bug described in Ticket #1778 on [the RTEMS Trac](https://devel.rtems.org/ticket/1778) Follow the [directions for this task](https://devel.rtems.org/wiki/GCI/QA/InvestigateTicket) on our wiki. The outcome of this task will be a comment on the ticket to suggest a path forward. If a bug fix is available || you may be expected to test the fix and possibly produce an updated patch. || 1 || "joelsherrill@gmail.com,gedarebloom@gmail.com,jenniferaverett@gmail.com" || "c,debugging" || false || "1,3,4" || 5 || bugfix |
