- Timestamp:
12/08/18 16:15:15 (6 years ago)
- Author:
Ludicrous
- Comment:
Legend:
- Unmodified
- Added
- Removed
- Modified
v26
v27
29 | 29 | || ShyMel || https://devel.rtems.org/wiki/Developer/OpenProjects || In the API Layers Projects section of the table the owner's name Joel should be capitalized |
30 | 30 | || ShyMel || https://devel.rtems.org/wiki/Developer/OpenProjects || 'USB stack - Ask about possible addition of other device types.' Should be rephrased to the possible addition of other device types. |
31 | | || ABR || https://devel.rtems.org/wiki/TBR/UserManual/Quick_Start || "Note, the following is for RTEMS 4.11, and assumes you have a valid sparc-rtems4.11-toolchain in your PATH." there should be no comma after 4.11. The irrelevant comas give an unneeded pause and disrupt user flow while reading. |
| 31 | || ABR || https://devel.rtems.org/wiki/TBR/UserManual/Quick_Start || "Note, the following is for RTEMS 4.11, and assumes you have a valid sparc-rtems4.11-toolchain in your PATH." there should be no comma after 4.11. The irrelevant comas give an unneeded pause and disrupt user flow while reading.\\ |
| 32 | || Ludicrous || [https://www.rtems.org] || 'Commercial support is available from US and European companies' 'From US' should be changed to 'from the US'.\\ |
| 33 | || Ludicrous || [https://www.rtems.org/news] || '04/05/2017; High Performance RTEMS SMP Presentation at DASIA2017' 'High Performance' should have a hyphen in it.\\ |
| 34 | || Ludicrous || [https://devel.rtems.org] || 'you need to build a cross-compiler tool set and RTEMS.' 'tool set' should be a single word (toolset).\\ |
| 35 | || Ludicrous || [https://www.rtems.org/license] || 'requires graphic to be displayed on website hosted' 'graphic' should be changed to 'graphics'.\\ |
| 36 | || Ludicrous || [https://www.rtems.org/license] || 'requires graphic to be displayed on website hosted' 'on website hosted' should be rephrased to 'on the website hosted'.\\ |
| 37 | |
32 | 38 | |
33 | 39 | |
