Changes between Version 24 and Version 25 of GCI/QA/ImproveEnglish
Ignore:
Timestamp:
Dec 8, 2018, 3:12:07 PM (6 months ago)
Author:
Gurveer Singh
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • GCI/QA/ImproveEnglish
    v24 v25
    1313
    1414|| Your GCI nickname || Web Page || Problem
     15|| Thegurshack || https://devel.rtems.org/wiki/GSoC/GettingStarted || 'You will be best served by using a GNU/Linux environment, which could be in a virtual machine for example' there is a missing comma between 'machine' and 'for'
    1516|| Thegurshack || https://devel.rtems.org/wiki/GSoC/GettingStarted || 'The goal of this page is to help you get RTEMS compiled and running so you can start the real work.' The word 'with' should be added between 'start' and 'the'
    1617|| Thegurshack || https://devel.rtems.org/wiki/TBR/Website/Wheres_RTEMS || 'Just because you downloaded RTEMS and used it in an application, doesn't mean we know anyhting about you, the application, or where it is in use' the word 'anything should be replaced with the word 'everything'
