Changes between Version 4 and Version 5 of GCI/Coding/POSIXTimingTest
Ignore:
Timestamp:
Nov 14, 2018, 12:13:45 AM (2 years ago)
Author:
ornitokya
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • GCI/Coding/POSIXTimingTest
    v4 v5
    8484
    8585== Directions for Mentors ==
    86 This should be evaluated as a normal code submission. You need to review and run the test to ensure it is correct. It should be based upon the templates in rtems-testing. The student should provide a name and email for proper attribution. If you have write permission, commit it. Otherwise, send it to rtems-devel for another developer to commit with commentary indicating it is acceptable and from GCI.
     86This should be evaluated as a normal code submission. You need to review and run the test to ensure it is correct. It should be based on the templates in rtems-testing. The student should provide a name and email for proper attribution. If you have write permission, commit it. Otherwise, send it to rtems-devel for another developer to commit with commentary indicating it is acceptable and from GCI.
