Changes between Version 28 and Version 29 of GCI/Coding/HelloWorld
Ignore:
Timestamp:
Nov 3, 2018, 7:01:15 PM (11 months ago)
Author:
shashvat jain
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • GCI/Coding/HelloWorld
    v28 v29
    3939|| Sal || Fedora 28 || sparc-rtems5 || I think that the instructions are well explained but in the wiki, you have to jump from page to page to find everything and there are some things that seem outdated. I think that it would be better to have a unified page with a simple step-by-step explanation of the installation process and then put links for more specific things.
    4040|| embeddedt || Ubuntu 16.04 || sparc-rtems5 || Once I found the necessary commands to invoke, the RTEMS Source Builder behaved as it was supposed to. However, I ended up having to search for several documentation pages because they were either missing or difficult to find. I think that a new document should be made that contains either the whole set of steps to follow or all the links we need.
    41 || Shashvat || CentOS 7 || sparc-rtems5 || The process described to set up the host operating system was very well compiled , the major problem i faced was that most of the documents envolved for building the rtems5 were not systematically arranged ,the process of quick start should be more explained(it was a bit vague at points.) , i suppose the explainations of various new topics(for me) like BSD(Broad support packages),Targets and architectures should be linked to the quick start , where they are first used. I faced recursive errors due to presence of corrupt files in kernel but later i decided to rebuild the system entirely and the second time it felt much easier .The mentors were very helpful , helped me get through the quick start guide(do not hesitate to ask them questions).
     41|| Shashvat || CentOS 7 and Ubuntu 18.04 || sparc-rtems5 || The process described to set up the host operating system was very well compiled , the major problem i faced was that most of the documents envolved for building the rtems5 were not systematically arranged ,the process of quick start should be more explained(it was a bit vague at points.) , i suppose the explainations of various new topics(for me) like BSD(Broad support packages),Targets and architectures should be linked to the quick start , where they are first used. I faced recursive errors due to presence of corrupt files in kernel but later i decided to rebuild the system entirely and the second time it felt much easier .The mentors were very helpful , helped me get through the quick start guide(do not hesitate to ask them questions).the ubuntu installation was quite similar but i faced error while bootstraping as the command was unable to access python lib , so i gave the path again and it worked fine .good luck!!
    4242|| zehata || Ubuntu 18.04.1 || sparc-rtems5 || While the process is relatively straightforward, there are a few changes that should be made to complete the task successfully. For example, instructions on https://docs.rtems.org/branches/master/user/start/index.html had linked to the Windows-specific guide. Between the 2 code blocks, it was stated that "Build the RTEMS Kernel (Chapter 7 Section 3.2.2 - Building the Kernel) by cloning the repository, running the bootstrap procecure, building and finally installing the kernel:", but 7.3.2.2 is for Windows Hosts only, so I met with some roadblocks when trying to run the code.
    4343|| Himanshu || Fedora 28 || sparc-rtems5 || The steps for installation and setting up host operating system was very well compiled. Only problem that I faced which is not a big deal during starting of the compilation like changing path from chris user to $HOME which is mentioned in the [https://docs.rtems.org/branches/master/user/start/index.html] . And everything was fine and program run successfully. Problem arises when I visited old sites for compiling rtems and after on-wards I followed the updated guide which leads me to successful compilation of the program. I think old sites should be either updated or merged. Actually saying a simple step-by-step explanation should be there and then put some extra links for more specific things
