Changes between Version 25 and Version 26 of GCI/Coding/HelloWorld
Ignore:
Timestamp:
Oct 27, 2018, 3:04:40 PM (12 months ago)
Author:
Himanshu Sekhar Nayak
Comment:
Added a feddback
Legend:
Unmodified
Added
Removed
Modified
  • GCI/Coding/HelloWorld
    v25 v26
    4141|| Shashvat || CentOS 7 || sparc-rtems5 || The process described to set up the host operating system was very well compiled , the major problem i faced was that most of the documents envolved for building the rtems5 were not systematically arranged ,the process of quick start should be more explained(it was a bit vague at points.) , i suppose the explainations of various new topics(for me) like BSD(Broad support packages),Targets and architectures should be linked to the quick start , where they are first used. I faced recursive errors due to presence of corrupt files in kernel but later i decided to rebuild the system entirely and the second time it felt much easier .The mentors were very helpful , helped me get through the quick start guide(do not hesitate to ask them questions).
    4242|| zehata || Ubuntu 18.04.1 || sparc-rtems5 || While the process is relatively straightforward, there are a few changes that should be made to complete the task successfully. For example, instructions on https://docs.rtems.org/branches/master/user/start/index.html had linked to the Windows-specific guide. Between the 2 code blocks, it was stated that "Build the RTEMS Kernel (Chapter 7 Section 3.2.2 - Building the Kernel) by cloning the repository, running the bootstrap procecure, building and finally installing the kernel:", but 7.3.2.2 is for Windows Hosts only, so I met with some roadblocks when trying to run the code.
     43|| Himanshu || Fedora 28 || sparc-rtems5 || The steps for installation and setting up host operating system was very well compiled. Only problem that I faced which is not a big deal during starting of the compilation like changing path from chris user to $HOME which is mentioned in the [https://docs.rtems.org/branches/master/user/start/index.html] . And everything was fine and program run successfully.
    4344
    4445== Directions for Mentors ==
