Changes between Version 22 and Version 23 of GCI/Coding/HelloWorld
Ignore:
Timestamp:
Oct 26, 2018, 8:09:58 AM (6 months ago)
Author:
Amaan Cheval
Comment:
Make deliverable requirements clearer
Legend:
Unmodified
Added
Removed
Modified
  • GCI/Coding/HelloWorld
    v22 v23
    1414  * In many cases, you can use [http://www.virtualbox.org Virtualbox] to execute the operating system virtually. Many operating system images are available are available at https://virtualboxes.org/images/ and https://www.osboxes.org/virtualbox-images/. This allows you to use a Windows computer to run a virtual machine with GNU/Linux or FreeBSD. Note that the virtual machines there may need to be updated and have extra packages installed to be suitable for building RTEMS tools and RTEMS itself.
    1515 *  Build your own tools using the [wiki:Developer/Tools/RSB RTEMS Source Builder (RSB)] add "no clean" option and report the disk space used by the build, and the build time along with specs on the machine and OS you used.
    16  *  '''Report back on the process''' to help us improve the [wiki:GSoC/GettingStarted GSoC Getting Started] page to be current, clear, and correct.
    17  *  '''Submit a git patch''' [https://devel.rtems.org/wiki/Developer/Git/Users#CreatingaPatch HowTo create git patch] to your GCI claimed task (GCI website).
     16 *  '''Report back on the process''' to help us improve the [wiki:GSoC/GettingStarted GSoC Getting Started] page to be current, clear, and correct, if you run into any issues.
     17 * If you run into trouble, ask for help on the [wiki:TBR/Website/RTEMSMailingLists RTEMS Users mailing list], [wiki:Developer/IRC IRC channel], or use Google to search for similar problems others may have experienced before.
     18
     19=== Deliverables for submission ===
     20
     21 *  '''Submit a git patch''' [https://devel.rtems.org/wiki/Developer/Git/Users#CreatingaPatch HowTo create git patch] to your GCI claimed task (GCI website), which shows you having edited the hello world program with your own custom message.
    1822 *  '''Submit a screenshot''' of your modified running Hello World program to your GCI claimed task (GCI website).
    1923 *  Fill in an entry in the Feedback table below.
    20  * If you run into trouble, ask for help on the [wiki:TBR/Website/RTEMSMailingLists RTEMS Users mailing list], [wiki:Developer/IRC IRC channel], or use Google to search for similar problems others may have experienced before.
     24
    2125=== Feedback ===
    2226
    3438|| embeddedt || Ubuntu 16.04 || sparc-rtems5 || Once I found the necessary commands to invoke, the RTEMS Source Builder behaved as it was supposed to. However, I ended up having to search for several documentation pages because they were either missing or difficult to find. I think that a new document should be made that contains either the whole set of steps to follow or all the links we need.
    3539|| Shashvat || CentOS 7 || sparc-rtems5 || The process described to set up the host operating system was very well compiled , the major problem i faced was that most of the documents envolved for building the rtems5 were not systematically arranged ,the process of quick start should be more explained(it was a bit vague at points.) , i suppose the explainations of various new topics(for me) like BSD(Broad support packages),Targets and architectures should be linked to the quick start , where they are first used. I faced recursive errors due to presence of corrupt files in kernel but later i decided to rebuild the system entirely and the second time it felt much easier .The mentors were very helpful , helped me get through the quick start guide(do not hesitate to ask them questions).
     40
    3641== Directions for Mentors ==
    3742Verify the patch, screenshot, and read the feedback above.
