Changes between Version 17 and Version 18 of GCI/Coding/HelloWorld
Ignore:
Timestamp:
Oct 23, 2018, 9:37:26 PM (6 months ago)
Author:
Sal
Comment:
added my feedback
Legend:
Unmodified
Added
Removed
Modified
  • GCI/Coding/HelloWorld
    v17 v18
    3131|| Michał || Arch Linux || sparc-rtems4.11 || Instructions were relly easy to follow, I had no problem building RTEMS. Unfortunatelly, RSB scripts assume that {{{/usr/bin/python}}} is {{{python2}}}, but that's an issue with nearly every build script and it's easy to solve, so it was not a big problem.
    3232|| OP. || Ubuntu and OS X || sparc-rtems4.11 || When I built RTEMS the first time on Ubuntu, I thought the instructions were relatively clear, but at sometimes seemed vague to me. I had a few errors when trying to build the tool set with RSB, so I had to dig around in the log files multiple times. When I built RTEMS on OS X, it didn't take long and I found it much easier than doing it on Ubuntu, probably because I already had experience. I was able to get it working the first time.
     33|| Sal || Fedora 28 || sparc-rtems5 || I think that the instructions are well explained but in the wiki, you have to jump from page to page to find everything and there are some things that seem outdated. I think that it would be better to have a unified page with a simple step-by-step explanation of the installation process and then put links for more specific things.
    3334
    3435== Directions for Mentors ==
