Changes between Version 26 and Version 27 of Developer/VirtualMachines/VirtualBox
- Timestamp:
- 02/28/18 14:52:32 (5 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v26 v27 299 299 }}} 300 300 301 I have not been able to get mtools to work properly when built from MSYS or MSYS2. The directory tools and the tools that copy to the image seem to work fine, but I can't copy from the image to the host or use mtype to display the contents on the disk image. 301 mtools works fine under Cygwin on Windows. When using mtools from MSYS or MSYS2 on Windows you must use the -i option to specify the image. (You can not use drive letter notation because mtools can not differentiate between the image and a host drive.) 302 302 303 303 === Disk Management Tool (Windows) ===
