- Timestamp:
06/10/10 20:39:33 (14 years ago)
- Author:
Gedare
- Comment:
Legend:
- Unmodified
- Added
- Removed
- Modified
v13
v14
2 | 2 | |
3 | 3 | |
4 | | You can run RTEMS in the [http://www.virtualbox.org/ VirtualBox] x86 virtualizer. |
5 | | |
6 | | The main advantage of VirtualBox over other virtualizers is that it provides several board/controller emulation options, including a SATA controller and several network adapters.= Introduction = |
7 | | |
8 | | This page describes how to setup a “one click solution” for booting RTEMS in VirtualBox; if the RTEMS application gets updated is just a matter of rebooting the virtual machine to boot the new updated application. |
| 4 | You can run RTEMS in the [http://www.virtualbox.org/ VirtualBox] x86 emulator. |
| 5 | |
| 6 | The main advantage of VirtualBox over other emulators is that it provides several board/controller emulation options, including a SATA controller and several network adapters. |
| 7 | = Introduction = |
| 8 | |
| 9 | This page describes how to setup a “one click solution” for booting RTEMS in VirtualBox; if the RTEMS application gets updated, it is just a matter of rebooting the virtual machine to boot the new updated application. |
9 | 10 | |
10 | 11 | A solution for debugging RTEMS remotely through VirtualBox serial port is also described. = What we will need? = |
