- Timestamp:
05/25/13 19:19:25 (11 years ago)
- Author:
C Rempel
- Comment:
remove outdated information
Legend:
- Unmodified
- Added
- Removed
- Modified
v10
v11
37 | 37 | = Miscellaneous Sections = |
38 | 38 | |
39 | | As the project progresses, you will need to add build instructions, etc and this page will evolve from a project description into a HOWTO.= Source Builder Quick Start = |
40 | | |
41 | | In Ubuntu: |
42 | | |
43 | | sudo apt-get build-dep binutils gcc g++ gdb # install the build dependencies |
44 | | |
45 | | In Debian, it is necessary to do the build completely as the root user, and manually install automake and expat. |
46 | | su root |
47 | | apt-get install automake expat |
48 | | '''Note:''' if using Debian continue to use the root user. |
49 | | |
50 | | Platform independent: |
51 | | git clone git://git.rtems.org/chrisj/rtems-source-builder.git # clone the repository |
52 | | cd rtems-source-builder-rtems/rtems # move to the RTEMS directory |
53 | | ../source-builder/sb-set-builder --list-bsets # list the build sets |
54 | | ../source-builder/sb-set-builder 4.11/rtems-sparc --force # force the build of the sparc set |
55 | | |
56 | | The packages will then be built in the ''rtems-source-builder-rtems/rtems/tar'' directory, and can be used by navigating to where to install the tools and running |
57 | | tar -xf ''path/to/rtems-source-builder/rtems/tar''/sparc-rtems4.11-binutils-2.22-1.tar.bz2 |
58 | | tar -xf ''path/to/rtems-source-builder/rtems/tar''/sparc-rtems4.11-gcc-4.7.2-newlib-1.20.0-1.tar.bz2 |
59 | | tar -xf ''path/to/rtems-source-builder/rtems/tar''/sparc-rtems4.11-gdb-7.5.1-1.tar.bz2 |
60 | | tar -xf ''path/to/rtems-source-builder/rtems/tar''/rtems4.11-sparc-rtems4.11-1.tar.bz2 |
61 | | = References = |
| 39 | As the project progresses, you will need to add build instructions, etc and this page will evolve from a project description into a HOWTO.= References = |
62 | 40 | |
63 | 41 | |
