Changes between Version 1 and Version 2 of Developer/Simulators/gem5
- Timestamp:
- 11/09/17 06:51:54 (6 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v1 v2 17 17 If you succeeded at running `scons build/ARM/gem5.opt` (or similar), and you have configured and compiled RTEMS for the realview_pbx_a9_qemu BSP, you can run applications using a command such as: 18 18 ``` 19 build/ARM/gem5.opt configs/example/fs.py --kernel=${HOME}/work/rtems/builds/b-realview/arm-rtems 4.12/c/realview_pbx_a9_qemu/testsuites/samples/ticker/ticker.exe --mem-size=256MB --bare-metal --machine-type=RealView_PBX --dtb-filename=None --enable-security-extensions19 build/ARM/gem5.opt configs/example/fs.py --kernel=${HOME}/work/rtems/builds/b-realview/arm-rtems5/c/realview_pbx_a9_qemu/testsuites/samples/ticker/ticker.exe --mem-size=256MB --bare-metal --machine-type=RealView_PBX --dtb-filename=None --enable-security-extensions 20 20 ``` 21 21
