Changes between Version 37 and Version 38 of Developer/Simulators/QEMU
Ignore:
Timestamp:
Jun 5, 2010, 4:47:51 PM (9 years ago)
Author:
Gedare
Comment:
/* Using the rtems-testing Module */
Legend:
Unmodified
Added
Removed
Modified
  • Developer/Simulators/QEMU
    v37 v38
    140140
    141141to load and run your image.
    142 = Using the gcc-testing Module =
    143
    144
    145 The automated testing infrastructure provided by the gcc-testing module from CVS can be used to run applications in QEMU.
    146
    147 The first step is to check out gcc-testing from CVS.  Instructions can be found on the [wiki:TBR/Delete/RTEMS_CVS_Repository RTEMS CVS Repository] page.
     142= Using the rtems-testing Module =
     143
     144
     145The automated testing infrastructure provided by the rtems-testing (formerly gcc-testing) module from CVS can be used to run applications in QEMU.
     146
     147The first step is to check out rtems-testing from CVS.  Instructions can be found on the [wiki:TBR/Delete/RTEMS_CVS_Repository RTEMS CVS Repository] page.
    148148
    149149Create two directories, ~/qemu and ~/qemu/hd.
    151151  mkdir ~/qemu/hd
    152152
    153 There is a qemu-support directory in gcc-testing with a boot floppy image. Copy gcc-testing/qemu-support/pc386_fda.bz2 to ~/qemu.
     153There is a qemu-support directory in rtems-testing with a boot floppy image. Copy rtems-testing/qemu-support/pc386_fda.bz2 to ~/qemu.
    154154  cp ./qemu-support/pc386_fda.bz2 ~/qemu
    155155
