Changes between Version 30 and Version 31 of Developer/Simulators/QEMU
- Timestamp:
- 06/10/09 07:28:29 (15 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v30 v31 114 114 '''-fda <path to rtems-boot.img>''' defines the second best floppy disk image 115 115 '''-hda <path to hda.img>''' defines the first hard disk image 116 '''-hdb fat:.''' says hdb is fat disk and . is the directory to make the root of that disk and '''-hdb''' is the mapping to the local disk so we can read the RTEMS executable into memory 116 '''-hdb fat:.''' says hdb is fat disk and . is the directory to make the root of that disk and 117 '''-hdb''' is the mapping to the local disk so we can read the RTEMS executable into memory 117 118 '''-serial stdio''' directs the serial port to the stdio of qemu 118 119 '''-no-reboot''' tells Qemu to not reboot if the code running wants to. Stops an error looping over and over.
