Changes between Version 21 and Version 22 of Developer/Simulators/QEMU
- Timestamp:
- 04/24/07 20:36:24 (17 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v21 v22 121 121 multiboot (hd0,0)/iostream/iostream.exe 122 122 } 123 124 (Note: I ''think'' that all references to (hd0,0) in the script and configuration file above should be changed to (hd0,1). The GRUB partition numbering scheme used in the latest versions of GRUB now start partition numbering at 1 instead of 0.) 123 125 = Running Other Images = 124 126 … … 141 143 142 144 to load and run your image. 143 144 (Note: Although the example configuration file above uses the notation (hd0,0) to refer to the first partition on the first drive, the latest versions of GRUB now start partition numbering at 1 instead of 0. The "(hd0,0)" in the script should also be changed to "(hd0,1)", otherwise the GRUB prompt will appear instead of the menu.)145 145 = Debugging with QEMU = 146 146
