Changes between Version 31 and Version 32 of Developer/Simulators/QEMU/CANEmulation
Ignore:
Timestamp:
Aug 14, 2013, 8:39:45 AM (7 years ago)
Author:
C Rempel
Comment:
/* Installing Prerequisite Software */
Legend:
Unmodified
Added
Removed
Modified
  • Developer/Simulators/QEMU/CANEmulation
    v31 v32
    173173'''NOTE:''' before you compile QEMU, "libglib2-dev" should be installed, or you will get the error "ERROR: glib-2.12 required to compile QEMU". In Ubuntu, to do that we use command
    174174 sudo apt-get install libglib2-dev
     175==  Installing Qemu  ==
     176
     177The project is hosted in a public repository which the developer has access to. For Summer of Code projects for RTEMS, as of 2013, github was the preferred repository.
    175178
    176179You can download the qemu-can project from https://github.com/Jin-Yang/QEMU-1.4.2 or get a copy using the following command(Linux).
