Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
Changes between Version 12 and Version 13 of Developer/Simulators/QEMU/CANEmulation
Ignore:
Timestamp:
06/10/13 08:38:57 (11 years ago)
Author:
Jinyang
Comment:
/* RTEMS environment */
Legend:
Unmodified
Added
Removed
Modified
  • Developer/Simulators/QEMU/CANEmulation
    v12 v13
    172172= RTEMS environment =
    173173
    174 You can get a basic simulation environment from https://github.com/Jin-Yang/RTEMS-QEMU. This is simple environment, before run the RTEMS PATH and RTEMS_MAKEFILE_PATH should be added to ~/.bashrc, such as
     174You can get a basic simulation environment from https://github.com/Jin-Yang/RTEMS-QEMU. This is a simple environment. However before run the RTEMS, environment variables 'PATH' and 'RTEMS_MAKEFILE_PATH' should be added to ~/.bashrc, such as
    175175   export PATH=/opt/rtems-4.10/bin:${PATH}
    176176   export RTEMS_MAKEFILE_PATH=/opt/rtems-4.10/i386-rtems4.10/pc386
    177 You can run it just using
     177Then, you can run it just using
    178178   ./qemu
    179 Source file located at examples-v2/ and before runing the simulation rtems-grub.cfg should be edited.
    180179
     180Source file located at examples-v2/ and before runing, rtems-grub.cfg should be edited too.
    181181=  References  =
    182182
