Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
Changes between Version 11 and Version 12 of Developer/Simulators/QEMU/CANEmulation
Ignore:
Timestamp:
06/10/13 08:35:33 (11 years ago)
Author:
Jinyang
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • Developer/Simulators/QEMU/CANEmulation
    v11 v12
    170170Then you can build it through
    171171  ./configure --prefix=/opt/qemu && make && make install
     172= RTEMS environment =
     173
     174You can get a basic simulation environment from https://github.com/Jin-Yang/RTEMS-QEMU. This is simple environment, before run the RTEMS PATH and RTEMS_MAKEFILE_PATH should be added to ~/.bashrc, such as
     175   export PATH=/opt/rtems-4.10/bin:${PATH}
     176   export RTEMS_MAKEFILE_PATH=/opt/rtems-4.10/i386-rtems4.10/pc386
     177You can run it just using
     178   ./qemu
     179Source file located at examples-v2/ and before runing the simulation rtems-grub.cfg should be edited.
    172180
    173181=  References  =
