Changes between Version 51 and Version 52 of Developer/SMP
- Timestamp:
- 03/06/14 13:22:13 (10 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
Developer/SMP
v51 v52 41 41 * The POSIX key destructor shall execute in the context of the deleted thread. 42 42 * The POSIX key destructor shall execute in case a thread is re-started in the context of the re-started thread. 43 * In case a thread owns operating system provided resources after the cleanup procedure, then this shall result in a fatal error.43 * In case a thread owns semaphore objects after the cleanup procedure, then this shall result in a fatal error. 44 44 * Non-Thread Object Life Cycle 45 45 * Concurrent object deletion is for example deletion requests issued by multiple threads for one object or usage of an object while a deletion request was issued. … … 1495 1495 * explicit thread migration, e.g. if a thread should move from one scheduler domain to another, 1496 1496 * thread deletion, since the thread stack is in use until the thread stopped execution, or 1497 * re 1497 * restart of threads e
