Changes between Version 14 and Version 15 of Developer/Release
- Timestamp:
- 11/10/16 01:21:32 (7 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
Developer/Release
v14 v15 38 38 1. RTEMS Source Builder ([https://git.rtems.org/rtems-source-builder.git git://git.rtems.org/rtems-source-builder.git]) 39 39 1. RTEMS Tools ([https://git.rtems.org/rtems-tools.git git://git.rtems.org/rtems-tools.git]) 40 1. RTEMS Testing Support ([https://git.rtems.org/rtems-testing.git git://git.rtems.org/rtems-testing.git])40 1. RTEMS Documentation ([https://git.rtems.org/rtems-docs.git git://git.rtems.org/rtems-docs.git]) 41 41 1. Example applications ([https://git.rtems.org/examples-v2.git git://git.rtems.org/examples-v2.git]) 42 42 1. Networking examples ([https://git.rtems.org/network-demos.git git://git.rtems.org/network-demos.git]) … … 73 73 74 74 ---- 75 ----76 75 77 76 = Pre-Release Checklist = … … 89 88 * Review contents of top of each repo for being up to date. 90 89 90 ---- 91 91 92 = Release Procedures = 92 93 … … 97 98 98 99 == Create a Release Branch for new Major or Minor == 100 99 101 1. Create branch for release, for example `git checkout -b 4.11` 100 102 1. Follow the steps below for Create a Release Branch Release. … … 107 109 108 110 == Create a Release Branch Release == 111 109 112 1. Switch to Release Branch, for example `git checkout 4.11`. 110 113 1. Run release.sh in Dot (D) mode, for example `./release.sh -V 4.11.0 -M 4.11 -D`. … … 118 121 1. RSB 119 122 120 ---- 123 == Releasing Process == 121 124 122 = Snapshot = 125 1. This procedure is run and tested on FreeBSD. It uses a large amount of bandwidth and so it typically run `sync.rtems.org`. 126 1. Documentation is built and this includes PDF there a valid documentation build environment is required including production quality fonts. 123 127 124 There are no snapshots as of yet. 128 Clone the [https://git.rtems.org/rtems-release/ RTEMS Release] repository and create the release providing the release's branch and the dot release number: 129 130 {{{ 131 $ git clone git://git.rtems.org/rtems-release.git 132 $ cd rtems-release 133 $ ./rtems-release 4.11 0 134 }}} 135 136 ```NOTE:``` for a release candidate use `0-rc1` as the dot release number.
