Changes between Version 61 and Version 62 of Developer/Projects/Open/TraceTool
Ignore:
Timestamp:
Aug 11, 2009, 8:18:06 PM (10 years ago)
Author:
Cocanlucian
Comment:
/* Main configuration file – default: rtems-trace.cfg */
Legend:
Unmodified
Added
Removed
Modified
  • Developer/Projects/Open/TraceTool
    v61 v62
    142142   '''rtems-functions''': rtems_task_create, rtems_task_delete <BR>
    143143   # Specify a manager from an API.
    144    # API_name-manager_name <BR>
    145145   '''rtems-managers''': classic-task, classic-interrupt, classic-clock, classic-timer, classic-semaphore,
    146146                   classic-message, classic-event, classic-signal, classic-io, classic-init,
    147147                   posix-mutex, posix-semaphore, posix-clock, posix-timer, posix-condvar,
    148                    posix-scheduler, posix-message
    149    # Specify a hole API. <BR>
    150    '''rtems-api''': classic, posix
    151    # Specify the libraries. <BR>
    152    '''rtems-libraries''': librtems.a, librtemscpu.a, libposix.a
    153    # The path to the symbols files.<BR>
     148                   posix-scheduler, posix-message <BR>
     150   '''rtems-api''': classic, posix <BR>
     152   '''rtems-libraries''': librtems.a, librtemscpu.a, libposix.a <BR>
    154154   '''rtems-symbols-path''': /home/cocan/Faculta/RTEMS/gsoc_2009/branch-rtems-trace/rtems-trace/bin/rtems-trace/symbols/librtems/
    155155= API configuration file =
