Changes between Version 52 and Version 53 of Developer/Projects/Open/TraceTool
- Timestamp:
- 08/10/09 20:31:36 (15 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v52 v53 21 21 '''--config'''=''path to the configuration file'' 22 22 23 Using this mode the user will generate the wrapping code, which is a set of files corresponding to the functions that he specified in the configuration file. If the --mode option it's not specified then the default mode chosen by the tool will be ''generate''. So if the user wants to generate and save the wrapping code in a directory named ''wrappers'' from the current working directory (cwd) which is the default path, then he can simply do this:23 Using this mode the user will generate the wrapping code, which is a set of files corresponding to the functions that he specified in the configuration file. If the --mode option it's not specified then the default mode chosen by the tool will be ''generate''. If the -c (--config) option it's not specified, then the tool will always look for the default configuration file ''rtems-trace.cfg'' from your current working directory. So if the user wants to generate and save the wrapping code in a directory named ''wrappers'' from the current working directory (cwd) which is the default path, then he can simply do this: 24 24 25 25 ./rtems_trace.py … … 196 196 = Tutorial = 197 197 198 The following section will try to illustrate how to properly use the RTEMS trace tool in order to get the decoded file containing the information needed. 198 The following section will try to illustrate how to properly use the RTEMS trace tool in order to get the decoded file containing the information needed. The BSP used is i386 and the RTEMS version is 4.10. 199 199 200 200 * Set up the configuration file as explained [http://www.rtems.org/wiki/index.php/RTEMS_Trace_Tool#Configuration_files here]. 201 201 * Generate the wrapping code: 202 202 203 ./rtems_trace.py --mode=generate 204 205 If the -c (--config) option it's not specified, then the tool will always look for the default configuration file '''rtems-trace.cfg''' from your current working directory. Also, if the 203 ./rtems_trace.py 204 205 * Compile the wrapping and the application code (copy your application code in the ''cwd/wrappers'' directory). 206 207 ./rtems_trace.py --mode=compile --compiler=i386-rtems4.10-gcc 208 209 * Do the linking. 210 211 ./rtems_trace.py --mode=link --compiler=i386-rtems4.10-gcc -build=/home/cocan/Faculta/RTEMS/build-i386-qemu-rtems 212 213 * Run the final executable in QEMU in order to get the trace file needed for decoding. 214 TBD 215 * Decode the trace file (copy the trace file in ''cwd''). 216 217 ./rtems_trace.py --mode=decode 218 219 This is it. All the tracing information it's now saved in the ''cwd/decoded.txt'' file.
