Changes between Version 49 and Version 50 of Developer/Projects/Open/TraceTool
Ignore:
Timestamp:
Aug 10, 2009, 8:21:37 PM (10 years ago)
Author:
Cocanlucian
Comment:
/* Tutorial */
Legend:
Unmodified
Added
Removed
Modified
  • Developer/Projects/Open/TraceTool
    v49 v50
    198198The following section will try to illustrate how to properly use the RTEMS trace tool in order to get the decoded file containing the information needed.
    199199
    200  *  Set up the configuration file as explained {{http://www.rtems.org/wiki/index.php/RTEMS_Trace_Tool#Configuration_files | here}}.
     200 *  Set up the configuration file as explained [http://www.rtems.org/wiki/index.php/RTEMS_Trace_Tool#Configuration_files | here].
    201201 *  Generate the wrapping code:
    202202
