- Timestamp:
08/10/09 20:07:34 (15 years ago)
- Author:
Cocanlucian
- Comment:
Legend:
- Unmodified
- Added
- Removed
- Modified
v42
v43
25 | 25 | |
26 | 26 | |
27 | | Usage: ./rtems_trace.py -m compile |
28 | | -i name of the compiler |
29 | | -g path to the wrapping code |
30 | | -o path to where the compiled wrapping code should be saved |
31 | | -l path to where the RTEMS libraries were installed |
32 | | ./rtems_trace.py --mode=compile |
33 | | --compiler=name of the compiler |
34 | | --genpath=path to the wrapping code |
35 | | --objpath=path to where the compiled wrapping code should be saved |
36 | | --lib=path to where the RTEMS libraries were installed |
| 27 | Usage: ./rtems_trace.py '''-m''' ''compile'' |
| 28 | '''-i''' ''name of the compiler'' |
| 29 | '''-g''' ''path to the wrapping code'' |
| 30 | '''-o''' ''path to where the compiled wrapping code should be saved'' |
| 31 | '''-l''' ''path to where the RTEMS libraries were installed'' |
| 32 | ./rtems_trace.py '''--mode'''=''compile'' |
| 33 | '''--compiler'''=''name of the compiler'' |
| 34 | '''--genpath'''=''path to the wrapping code'' |
| 35 | '''--objpath'''=''path to where the compiled wrapping code should be saved'' |
| 36 | '''--lib'''=''path to where the RTEMS libraries were installed'' |
37 | 37 | |
38 | 38 | Using this mode the user can compile all the .c files from a directory (usually the .c files from the wrapping code directory) and save the resulted files (.o files) in the directory specified by the -o option. If the -g and -o options are not specified then the rtems_trace tool will look in the ''wrappers'' directory located in cwd and save the .o files in a directory named ''objects'' also from cwd. Also, if the -l option it's not specified than the tool will choose this path by default: ''/opt/rtems-4.10/i386-rtems4.10/pc386/lib/''. |
47 | 47 | Usage: ./rtems_trace.py '''-m''' ''link'' |
48 | 48 | '''-i''' ''name of the compiler'' |
49 | | -b RTEMS build path |
50 | | -o path to the compiled code (.o files) |
51 | | - list of comma separated object files that should be included in the final executable |
52 | | -l path to where the RTEMS libraries were installed |
53 | | ./rtems_trace.py --mode=link |
54 | | --compiler=name of the compiler |
55 | | --build=RTEMS build path |
56 | | --objpath=path to the compiled code(.o files) |
57 | | --trace-o=list of comma separated object files that should be included in the final executable |
58 | | --lib path to where the RTEMS libraries were installed |
| 49 | '''-b''' ''RTEMS build path'' |
| 50 | '''-o''' ''path to the compiled code (.o files)'' |
| 51 | '''-''' ''list of comma separated object files that should be included in the final executable'' |
| 52 | '''-l''' ''path to where the RTEMS libraries were installed'' |
| 53 | ./rtems_trace.py '''--mode'''=''link'' |
| 54 | '''--compiler'''=''name of the compiler'' |
| 55 | '''--build'''=''RTEMS build path'' |
| 56 | '''--objpath'''=''path to the compiled code(.o files)'' |
| 57 | '''--trace-o'''=''list of comma separated object files that should be included in the final executable'' |
| 58 | '''--lib'''=''path to where the RTEMS libraries were installed'' |
59 | 59 | |
60 | 60 | In this mode, the RTEMS trace tool will link all the object files from the specified directory (or from the default one if no directory is specified using the -o or --objpath option) if the --trace-o option it's not used. The user can specify only a subset of object files to be included in the final executable using the --trace-o option. The final executable file is placed into the same directory where the object files are found, under the ''wrapper.exe'' name. |
180 | 180 | = How to use it = |
181 | 181 | |
| 182 | The following section will try to illustrate how to properly use the RTEMS trace tool in order to get the decoded file containing the information needed. |
182 | 183 | |
183 | 184 | * Set up the configuration file as explained here. |
