Changes between Version 41 and Version 42 of Developer/Projects/Open/TraceTool
- Timestamp:
- 08/10/09 20:02:45 (15 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v41 v42 14 14 15 15 16 Usage: ./rtems_trace.py -m generate17 -g path to where the wrapping code should be saved18 ./rtems_trace.py --mode=generate19 --genpath=path to where the wrapping code should be saved16 Usage: ./rtems_trace.py '''-m''' ''generate'' 17 '''-g''' ''path to where the wrapping code should be saved'' 18 ./rtems_trace.py '''--mode'''=''generate'' 19 '''--genpath'''=''path to where the wrapping code should be saved'' 20 20 21 21 Using this mode the user will generate the wrapping code, which is a set of files corresponding to the functions that he specified in the configuration file. If the --mode option it's not specified then the default mode chosen by the tool will be ''generate''. So if the user wants to generate and save the wrapping code in a directory named ''wrappers'' from the current working directory (cwd) which is the default path, then he can simply do this:
