Changes between Version 37 and Version 38 of Developer/Projects/Open/TraceTool
- Timestamp:
- 08/10/09 17:47:55 (15 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v37 v38 30 30 --objpath=path to where the compiled wrapping code should be saved 31 31 32 Using this mode the user can compile all the .c files from a directory (usually the .c files from the wrapping code directory) and save the resulted files (.o files) in the directory specified by the -o option. If the -g and -o options are not specified then the rtems_trace tool will look in the ''wrappers'' directory located in cwd and save the .o files in a directory named ''objects'' also from cwd. Also, if the -l option it's not specified than the tool will choose this path by default: ''/opt/rtems-4.10/i386-rtems4.10/pc386/lib/'' 32 Using this mode the user can compile all the .c files from a directory (usually the .c files from the wrapping code directory) and save the resulted files (.o files) in the directory specified by the -o option. If the -g and -o options are not specified then the rtems_trace tool will look in the ''wrappers'' directory located in cwd and save the .o files in a directory named ''objects'' also from cwd. Also, if the -l option it's not specified than the tool will choose this path by default: ''/opt/rtems-4.10/i386-rtems4.10/pc386/lib/''. 33 33 Example: 34 34
