- Timestamp:
08/10/09 17:46:10 (15 years ago)
- Author:
Cocanlucian
- Comment:
Legend:
- Unmodified
- Added
- Removed
- Modified
v35
v36
17 | 17 | ./rtems_trace.py --mode=generate --genpath=path to where the wrapping code should be saved |
18 | 18 | |
19 | | Using this mode the user will generate the wrapping code which is a set of files corresponding to the functions that he specified in the configuration file. |
20 | | If the --mode option it's not specified then the default mode chosen by the tool will be ''generate''. So if the user wants to generate and save the wrapping code in a directory named "wrappers" from the current working directory (cwd) which is the default path, the user can simply do this: |
| 19 | Using this mode the user will generate the wrapping code, which is a set of files corresponding to the functions that he specified in the configuration file. If the --mode option it's not specified then the default mode chosen by the tool will be ''generate''. So if the user wants to generate and save the wrapping code in a directory named ''wrappers'' from the current working directory (cwd) which is the default path, then he can simply do this: |
21 | 20 | |
22 | 21 | ./rtems_trace.py |
| 22 | = Compile mode = |
23 | 23 | |
24 | | * compile mode |
25 | | * link mode |
26 | | * decode mode |
| 24 | |
| 25 | Usage: ./rtems_trace.py -m compile -i name of the compiler -g path to the wrapping code |
| 26 | -o path to where the compiled wrapping code should be saved |
| 27 | -l path to where the RTEMS libraries were installed |
| 28 | ./rtems_trace.py --mode=compile --compiler=name of the compiler |
| 29 | --genpath=path to the wrapping code |
| 30 | --objpath=path to where the compiled wrapping code should be saved |
| 31 | |
| 32 | Using this mode the user can compile all the .c files from a directory (usually the .c files from the wrapping code directory) and save the resulted files (.o files) in the directory specified by the -o option. If the -g and -o options are not specified then the rtems_trace tool will look in the ''wrappers'' directory located in cwd and save the .o files in a directory named ''objects'' also from cwd. Also, if the -l option it's not specified than the tool will choose this path by default: ''/opt/rtems-4.10/i386-rtems4.10/pc386/lib/'' |
| 33 | |
| 34 | ./rtems_trace.py --mode=compile --compiler=i386-rtems4.10-gcc |
| 35 | |
| 36 | will compile all the .c files from the cwd/wrappers using the gcc compiler for the i386 BSP and the 4.10 rtems version. The .o files will be saved in cwd/objects. |
| 37 | = Link mode = |
| 38 | = Decode mode = |
| 39 | |
27 | 40 | = Configuration files = |
28 | 41 | |
