Changes between Version 34 and Version 35 of Developer/Projects/Open/TraceTool
Ignore:
Timestamp:
Aug 10, 2009, 5:11:16 PM (10 years ago)
Author:
Cocanlucian
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • Developer/Projects/Open/TraceTool
    v34 v35
    1414
    1515
    16 Usage: ./rtems_trace.py --mode=generate (this is by default) --genpath=path to where the wrapping code should be saved (the default is the ''wrappers'' directory from the cwd - current working directory).
     16  Usage: ./rtems_trace.py -m generate -g path to where the wrapping code should be saved
     17         ./rtems_trace.py --mode=generate --genpath=path to where the wrapping code should be saved
    1718
     19Using this mode the user will generate the wrapping code which is a set of files corresponding to the functions that he specified in the configuration file.
     20If the --mode option it's not specified then the default mode chosen by the tool will be ''generate''. So if the user wants to generate and save the wrapping code in a directory named "wrappers" from the current working directory (cwd) which is the default path, the user can simply do this:
     21
     22   ./rtems_trace.py
    1823
    1924 *  compile mode
    2025 *  link mode
    2126 *  decode mode
    22 To call the RTEMS Trace Tool a user should do this (from the directory where the tool it's installed):
    23
    24    ./rtems_trace.py
    25
    26 This will cause the tool to work
    27 These are the following options that the user can add when
    2827= Configuration files =
    2928
