Changes between Version 33 and Version 34 of Developer/Projects/Open/TraceTool
- Timestamp:
- 08/10/09 17:03:13 (15 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v33 v34 11 11 = Command line interface = 12 12 13 The RTEMS Trace Tool can currently work in 4 modes: 14 * generate mode 13 The RTEMS Trace Tool can currently work in 4 modes:= Generate mode = 14 15 16 Usage: ./rtems_trace.py --mode=generate (this is by default) --genpath=path to where the wrapping code should be saved (the default is the ''wrappers'' directory from the cwd - current working directory). 17 18 15 19 * compile mode 16 20 * link mode
