Changes between Version 1 and Version 2 of Developer/Projects/Open/TraceTool
Ignore:
Timestamp:
08/07/09 20:15:16 (15 years ago)
Author:
Cocanlucian
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • Developer/Projects/Open/TraceTool
    v1 v2
    2929
    3030rtems-functions: rtems_task_create, rtems_task_ident
    31                 rtems_task_self, rtems_task_start
    32                 rtems_task_restart, rtems_task_delete
    33                 rtems_task_suspend, rtems_task_resume
    34                 rtems_task_is_suspended, rtems_task_set_priority
    35                 rtems_task_mode, rtems_task_get_note
    36                 rtems_task_set_note, rtems_task_wake_after
    37                 rtems_task_wake_when, rtems_iterate_over_all_threads
    38                 rtems_task_variable_add, rtems_task_variable_get
    39                 rtems_task_variable_delete
    4040        I think you got the point. :)
    4141
    8181rtems-symbols-path: /home/cocan/Faculta/RTEMS/gsoc_2009/branch-rtems-trace/rtems-trace/bin/rtems-trace/symbols/librtems/
    8282
    83
    84 API configuration file
     83= API configuration file =
