28 | | rtems_task_self, rtems_task_start |
29 | | rtems_task_restart, rtems_task_delete |
30 | | rtems_task_suspend, rtems_task_resume |
31 | | rtems_task_is_suspended, rtems_task_set_priority |
32 | | rtems_task_mode, rtems_task_get_note |
33 | | rtems_task_set_note, rtems_task_wake_after |
34 | | rtems_task_wake_when, rtems_iterate_over_all_threads |
35 | | rtems_task_variable_add, rtems_task_variable_get |
36 | | rtems_task_variable_delete |
| 28 | rtems_task_self, rtems_task_start |
| 29 | rtems_task_restart, rtems_task_delete |
| 30 | rtems_task_suspend, rtems_task_resume |
| 31 | rtems_task_is_suspended, rtems_task_set_priority |
| 32 | rtems_task_mode, rtems_task_get_note |
| 33 | rtems_task_set_note, rtems_task_wake_after |
| 34 | rtems_task_wake_when, rtems_iterate_over_all_threads |
| 35 | rtems_task_variable_add, rtems_task_variable_get |
| 36 | rtems_task_variable_delete |
59 | | classic-message, classic-event, classic-signal, classic-io, classic-init, |
60 | | posix-mutex, posix-semaphore, posix-clock, posix-timer, posix-condvar, |
61 | | posix-scheduler, posix-message |
| 59 | classic-message, classic-event, classic-signal, classic-io, classic-init, |
| 60 | posix-mutex, posix-semaphore, posix-clock, posix-timer, posix-condvar, |
| 61 | posix-scheduler, posix-message |
