- Timestamp:
01/03/16 18:07:59 (8 years ago)
- Author:
Ralph Holmes
- Comment:
Fix spelling and/or grammar.
Legend:
- Unmodified
- Added
- Removed
- Modified
v2
v3
12 | 12 | There are 3 parts: |
13 | 13 | * The key definitions moved to rtems-lineeditor.h |
14 | | * The line editor function, ie rtems_shell_line_editor |
15 | | * The terminal parser, ie rtems_shell_getchar |
| 14 | * The line editor function, i.e. rtems_shell_line_editor |
| 15 | * The terminal parser, i.e. rtems_shell_getchar |
16 | 16 | |
17 | 17 | Some notes: The shell interface and code is better than the monitor. The shell uses FILE handles and this is nice for redirection and multi-user usage (a threaded version). It also supports a command history. The caller should provide the terminal type. This could be a string or a pointer to the terminal data returned to the caller after a call to get the terminal data with a string. It is recommended to review some of the keys actions, for example C-f, to make sure they are considered standard in relation to a normal shell. One should consider cutting out the code that disables echo and obtains the password and putting it in getpass(). See the linux man page. We don't |
