Changes between Initial Version and Version 1 of Developer/Projects/Open/ImproveSMP
Ignore:
Timestamp:
02/16/15 21:44:56 (8 years ago)
Author:
Gedare Bloom
Comment:
New Page with initial open project description.
Legend:
Unmodified
Added
Removed
Modified
  • Developer/Projects/Open/ImproveSMP
    v1 v1
     1= Improve RTEMS SMP =
     2
     3
     4[[TOC(Developer/Projects/Open/ImproveSMP, depth=2)]]
     5
     6
     7'''Mentors:''' Past, Present, and Potential Mentors
     8
     9'''Students:''' Past, Present, and Potential Students
     10
     11'''Status:''' Current status of project. For starting, it should be: Uninitiated.
     12
     13'''Introduction:''' Work on some aspect of [wiki:Developer/SMP SMP] support in RTEMS. There are many possible topics, and you should discuss your ideas with potential mentors and the developer community.
     14
     15'''Goal:''' Concise statement of the overall goal of the project. Refine this initial statement to include: project deliverables (code, docs, testing), required/suggested methodology, standards of quality, possible goal extensions beyond the main objective.
     16
     17'''Requirements:''' List the requirements and level of expertise you estimate are required by the developer tackling this project will have to have: Required level of programming language(s), specific areas of RTEMS or tools, level of familiarity with RTEMS, cross-development, GNU/Linux, etx., development/documentation/testing tools, mathematical/algorithmic background, other desirable skills.
     18
     19'''Resources:''' Current RTEMS developers, papers, etc that may help you in this project.
     20
     21'''Acknowledgements'''
     22 *  who helped and did work
     23
     24= Miscellaneous Sections =
     25
     26As the project progresses, you will need to add build instructions, etc and this page will evolve from a project description into a HOWTO.
     27
     28= References =
     29 *  TBD
     30
     31'''Other sections:''' If you have more to say about the project that doesn't fit in the proposed sections of this template, feel free to add other sections at will.
