| 1 | = Configuration GUI = |
| 2 | |
| 3 | |
| 4 | [[TOC(PAGE_LOCATION, depth=2)]] |
| 5 | |
| 6 | |
| 7 | '''Mentors:''' Amar Takhar |
| 8 | |
| 9 | '''Students:''' |
| 10 | |
| 11 | '''Status:''' Started - I hack on this one in a while, still a lot to be done. |
| 12 | |
| 13 | '''Introduction:''' This project involves creating a cross-platform GUI to configure a BSP for user building. This will use [wiki:waf/Config RTEMS Config] as it's base which holds all configuration information for RTEMS. There may be more information over at [wiki:waf/GUI]. |
| 14 | |
| 15 | |
| 16 | '''Goal:''' The end result of this project will be a bounds-checked input system. RTEMS supports lists of values, integers, strings which only have set values. The GUI should limit to these values only. There should be a comprehensive help system which utilises the already documented variable lists. |
| 17 | |
| 18 | '''Requirements:''' Anyone tacking this project must have strong Python capabilities and a cursory understanding of how GUIs work. I will help guide anyone working on this project to ensure we have a smooth GUI that works across all platforms. |
| 19 | |
| 20 | |
| 21 | '''Resources:''' [wiki:waf/Config RTEMS Config], [wiki:waf/Config RTEMS Config] - These pages still need to be filled out |
| 22 | |
| 23 | |
| 24 | '''Acknowledgements''' |
| 25 | * |
| 26 | |
| 27 | = Miscellaneous Sections = |
| 28 | |
| 29 | None yet. |
| 30 | |
| 31 | = References = |
| 32 | * TBD |
| 33 | |
| 34 | |
